terez
Stock 2013 Nytro FX studded.
3900 miles...this damn thing just gets stronger as it slooowwwly breaks in!!
I swapped in 14.5mm rollers lst yr...luv em..smoother engagement and better belt squeeze.
I went to a YPY spring as suggested and I was getting 8900~8950 shift rpm.
This year I'm getting 9100~rpm...and slightly lower top speed.
She's overevvin and not pullin.
These motors really don't fully breakin till around 4000 miles...!!
I know this topic is beat up but...
Should I go back to the stock spring or which spring to get the shift rpm back to 880 or so?
Or...I am convinced the sled needs a steeper helix. How about a oem Yamaha 47?
That should upshift harder and pull down my shift rpm a hundred or so no??
I'm not lookin to spend on a clutch kit...just twek the clutching with easily/inexpensive stuff.
A oem straight 47 or maybe an aftermarket 43/47?
What are you guys using with the 14.5mm rollers for a primary spring in a stock sled?
What about a helix for same?
Sea level trail riding, studded so traction not a concern, 210 geared up.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I run the 14.5's with a green pink green and the stock helix. Hits 9000
I have also used the 47 which is faster but I had more slipping and heat on clutchs
Sent from my XT1254 using Tapatalk
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I am running a OPO primary spring 14.5 rollers and a 43 helix on a 162 MTX. was pulling 9000 rpm when I had a Hindle Hurricane exhaust set up.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I run the 14.5's with a black \Heel clicker spring and 2-speed weights. Hold on............
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
^dammit i still want to run that setup. Just can't justify it with our past 2 crappy winters and now the dollar.
shadow44
Spend the money cheapskate lol
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
I run the 14.5's with a black \Heel clicker spring and 2-speed weights. Hold on............![]()
Mine eats heelclickers...I have 3 sets with groves on top of weights...I wonder if the stock rollers have anything to do with that??
