AttakDog
On the last day of our 7 day UP trip my nytro died. Its like the kill switch is pressed, no power anywhere. This was after riding in the 3 foot powder. Is there a main power fuse or relay? Where should I look?
AttakDog
I don't think its the starter relay since there is no power to the gauge even on the first click
nytroman20
Check your fuses on the right side next to your gearbox... Mine did this once.. Fuse burnt
AttakDog
OK I'll check them tomorrow. Thanks!
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Right next to the starter relay is a 30 or 40 amp main fuse, check that too.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The battery could have broke as well, make sure it's still 12V.
DeerHuntr
Check your battery connections are tight I had one loosen up did the same thing.
AttakDog
OK thanks for the help, It was the ignition switch. I don't see any corrosion, it's actually shorting around the wires behind the rubber boot. My dealer is getting me a new one and a updated starter relay with my YES coverage.
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
Got the P# on the updated relay?
