Nytro FX shock upgrades
terez
Ottawa ON Canada
2013 Nytro FX shorty
Is there an easy relatively cost effective way to add rezzies to the oem shocks?
They work OK when they're cool but fade VERY quickly......Rezzies improve this dramatically I would assume?
Don't have the funds to replace the shocks but could maybe swing adding rezzies when they are off for service/oil change.
Hygear most likely has a kit to add rezzies to your GYTRS. Might be less expensive thought to find some used Fox Floats with Rezzies.
Call hugear as you probably need a rebuild anyway, also check out hibsman (sp?) on here. He has a lot of factory and aftermarket nitro parts and shocks forsale so he may have a set you would like better.
One thing I've found as well as most the world, avoid the air shocks. They become overly complicated to achieve the same ride as a coil and one seal blows and your spring is gone. Also a ton of friction with all of the seals they use to try an hold air in.
No Floats for this guy.....coil overs ride so much better for trail riding. My shocks are not GTYR...they are non res KYB.
Either rezzies and a revalve or different shocks.
Hibsman has great quality stuff. Normally gytr with hugear upgrades in stock too at reasonable price
I have a set of gytr's from a 2010 xtx. I have the miles noted on the bag they are in. If your interested let me know!
i have a set of GYTR's that were rebuilt and re-valves by shocktec that i might sell.....
