blu blood
I thought my Apex was a pain. I hope I never have to do a plug change anywhere other than the garage. Three beer job!
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
blu blood said:I thought my Apex was a pain. I hope I never have to do a plug change anywhere other than the garage. Three beer job!
There is an easier way than going through removing all the plastic and tank. I was able to do mine by pulling side panels and using the deep socket that comes in tool pouch along with a multi-angled ratchet and magnetic tip. Still tough to get my fat hands in there but was under a 15min job.
good luck
Zakre
Yes I did it my first time not knowing Yamaha has a lovely too to use in the kit. It didn't take long though and was easy just used a plug socket and 6 " extension, just put them together with the socket in the cyl and they fit fine with tank and all. I think i will try the tool the next time and see which i prefer.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
X2, def no need to remove the tank and everything. go from the clutch side. use a spark plug socket and an extension or two. lucky if its a one beer job and i enjoy my beer lol.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
If you've upgraded to a Trail Tank, then you definitely have to remove the gas tank to change the plugs.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
Its the much bigger? there is quite a bit of room from the side to get in there. i just have a reg tank so IDK but i would still think you could get in there
phatkid
yes as grimm says if u have a trail tank absolutely have to remove it to change plugs no way u can get in there with that installed....
good luck getting tank back in after removal .....need lots and lots of patience
blu blood
billymx815 said:blu blood said:I thought my Apex was a pain. I hope I never have to do a plug change anywhere other than the garage. Three beer job!
good luck
gmfamily2008
Zakre said:Yes I did it my first time not knowing Yamaha has a lovely too to use in the kit. It didn't take long though and was easy just used a plug socket and 6 " extension, just put them together with the socket in the cyl and they fit fine with tank and all. I think i will try the tool the next time and see which i prefer.
better to leave the tool in the bag where it can sit and look pretty `cause thats about all its good for....... made real cheap twists apart if plugs are tight (and especially first time they are) I believe it is a 16 mm deep well that is needed with proper extension
