Nytro Powder Pro Mounts? Pictures?
bbrunick
Maple Grove, MN
Anyone got pictures of powder pro's mounted on a 09 Nytro? Can I use the stock rubbers? I just purchased a set used with Apex mounts and want to mount them this weekend. SLP website still doesn't list a Nytro mount.
I put the powder pros I had on my Rage on my 08 Nytro and they fit just fine.
If you have an RTX simply buy the ski mounting saddle for SkiDoo. They amost fit (cut on spacer 2mm needed). Add on 7mm rubber under the factory rubber bumper to avoid ski flap.
Works 100% on mine
Here are some pics. I used the stock XTX rubbers. I am running 6" shaper bars.
thanks. Mine have 6" shapers with an Apex mount so it looks like I"m set. Hopefully this improves the loose snow performance without increasing steering effort.
mounted them today. They look so much better than stock. Do I need to adjust toe in/out? It's tough to tell if they are straight given the "wings" on these skis.
Are people shimming them or just mount and go from stock?
I did not shim, but I did have to adjust the toe out after I mounted them. I went off the center line of the ski when I did my measurements
