blake
i have an 08 nytro rtx with skydog skis on it they have help with some darting but still does someone told me to shim the skis i serched for info but cant find any anyone know about this some info would be great thanks
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Go to the nytro faq sticky post, its the first one in the nytro section. It will help you with everything your are asking about. That should dial you in pretty good
dansranger
If you go on Bergstrom's website he has a lot of reading, which I found very helpful.
2BLUE4U
Adding Bergstrom ski savers will probably take care of it.
snow broke
Check your A-arm bushings...problem might be there. May be due for some oillites
- 6K
- 9K
