donkickit
- Sep 23, 2007
- Upstate New York near Albany
- 2014 viper ltx se
So, 1100 miles hyfax are shot on my 2011 nytro Rtx. Took the screw off front of hyfax , pryed them back 6 inches or so and it looks like they are wider than my track window. Do u have to cut the window to get them out? Any tips appreciated.
09NytroRTX
Cut the window to get them to fit through. Get them off a bit and then start sled and put in reverse and it will pry it right off.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
X2 on the reverse method. Works like a charm!
Lee Rivers
Have changed mine twice...they fit through the track, give it a little lube..it is tight but it does come through.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
They"ll fit and the reverse method is the bomb!
DON'T cut the track!
Supa Dexta
Why?^ Lots of people have trimmed a window and never had an issue.
There is no need to cut the track windows. Why cut on a track that doesn't need to be? Sounds crazy to me but if you want to cut it go ahead!
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
Use lots of silicone spray for removal and install. No need to cut the track. Its just a tight fit. Life lesson - tight hole, use more lube
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
donkickit
- Sep 23, 2007
- 2014 viper ltx se
I'm going to try loosening the track. 1 came off ok, the other not so much. Can't get it thru the track window. Reverse trick does work good once u gt it out the window.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
No cutting........... Just lots of LUBE, oh yea and put some more LUBE on it it will work.
