switch
What is the first thing that you are going to do to your sled. Aftermarket skis, clutch kit, trail tank or are you just going to leave it stock. Will these sleds get 100 miles to a tank? Thanks
100 miles is really pushing it if you ride aggressively and/or fast.
Grimm
I think I'm going to install a new track, probably the Ripsaw XT with the pre-installed studs.
NLVMAX
Putting a 1.5" Intense Powder Track on mine. Have it arranged with dealer to upgrade before I take it home. It's too bad you can't pre-order what track you want from the factory.
rage man
im just going to ride it i think it will already tuned to perfection
Noslip drivers and a bigger lug tack is a must in my opinion.
Thinking of a Cobra track. Anyone try one and how did it work?
AIRWOLF
Guest
Cobra track with anti rachet drivers
lucky_7
The first thing anybody should do (For those who ride aggressive) is stud the track and replace the skis.
100 miles per tank is pushing it....speaking from experience.
LJ 452
#1: Ulmer Oilite Front End Bushings
#2: Install Grease Zert fittings in front end Suspension.
#3: Install USI Tripple X2's.
#4: Heated shield harness.
#5: Top Secret
#6: Top Secret
#7: Top Secret
etc. etc. etc.
No Really with others ^^^^ on here I can't devulge everything. When it's done they'll be pics.
#5: Top Secret
#6: Top Secret
#7: Top Secret
etc. etc. etc.
08NitroRTX
Grimm
Also, I'll probably install an extra set of idlers just ahead of the rear axle. I don't want to change out 3 sets of sliders in one season EVER again (unless I ride over 10000 km), especially when it's -20 degrees outside.
dirkdiggler
Suspended
here are my mods
1. going to a 136
2. Going to a 9838 track
3. SkiDoo Extroverts
4. Slydog Skis not sure which kind yet.
5. 162 Studboy lakeracer studs
1. going to a 136
TurboJamie
After 08 I would just ride it stock until you know forsure all the 08 issues are fixed. Yamaha will blame any problem that comes up on an aftermarket part. If you have front end probs and the wrong dealer behind you aftermarket skis will void your warranty on a bent front end if that were to happen.
Just a heads uo to guys wanting to mod, I didn't fare to well with the USI Tripple threat skis they steer really heavy and dart around alot, this is with a 9" wear bar on them. You might have better luck with less carbide. I tried to move them around and shim them as well with little luck.
dirkdiggler
Suspended
I have a good friend that owned an 08 and spent a weekend on all the 09's. He said they where like two different sleds. I hope he's right
