Jeff p
- Nov 6, 2015
- rosemount Minnesota
- 08 fx nytro rtx
Hello all,new to the site,just purchased a 08 fx nytro rtx sled.was wondering what the big bottle opener looking thing in the tool kit is? Belt removal tool?any help would be appreciated.thanks,happy sledding
devilnabludress
- Aug 30, 2013
- Eastern Ontario
- 2011 Nytro XTX
Adjusting your shocks. Look on the base of your coil spring on the front shocks, and you will find a nut that you can turn to adjust load on the spring. The tab inserts into the notch of the nut so you can turn it.
Wrench for your shock, use it to loosen/tighten the lock collar and preload ring for the spring.
Dr. FeeLGooD
Do you have an owners manual?
Jeff p
- Nov 6, 2015
- 08 fx nytro rtx
No not yet,looking for a hard copy,figure I'll have to go through Yamaha?
Dr. FeeLGooD
Or post on the want adds here.
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
It's available online, I'll get you a link
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Spanner wrench
Jeff p
- Nov 6, 2015
- 08 fx nytro rtx
Thanks guys for all the info,the sled had fox float air shocks when I bought it ,and slydog skis.they told me it was set up for trail riding.just starting to get back into riding again after about 20 years.I've heard good things about the sleds,mostly worried about tunnel icing up and led tail light getting snow covered.had to try the 4 stroke.now i need snow in Minnesota to try it out
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
An exhaust cover in the tunnel under your pipe helps with icing as all the snow isn't hitting it.
Grab a piece of aluminum sheeting, bend to shape & rivet it on (mines on the protectors, like 14"x 36")?
Couple threads on here with good info.
I also added a Viper snow flap, think it helps cut down on spray out the back. My buddy said he sees the tail light better.
Could be a combination of both???
Have fun with it.
Have fun with it.
