extreman1
changed pullys now running 24-31 which mpi told me would be 13-14 lbs boost. i get only 10.4 lbs this is at sea level. any ideas ?? it was over reving to 9250 rpms i know i gotta get it to 8800-8900 rpms but lowering the rpms will lower boost is that correct?? is this combo of pullys correct for 13-14 lbs??
rj998
Did you put a larger spring in your blowoff valve...????
extreman1
they told me i didnt have to do anything with bov?
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Call ulmer he can set you up, and might have the pulley you need in stock.
rj998 said:Did you put a larger spring in your blowoff valve...????
X2 could be losing it thru your blowoff.
rj998 nice truck and love the buggy!
extreman1
thanks guys i will check the bov and call Ulmer
