kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
You haven't looked at or adjusted the map yourself? I wouldn't rely on a map file open up the RB3 on the laptop and see what its doing. I dont have a RB3 but I thought that was one of the highlights was being able to see so much more of what its doing.
No i got the map file from Powderlites. I have tried different map-files for both the stage 3 injectors and stock injectors ( last one does´nt even add any fuel on idle rpm ) but the problem is the same. And the diode ( Noid light ) is only lit not flashing.
There´s no reason to continue this investigation. Something is wrong, and i´m tired of spending hours in the garage to find nothing but trouble with the unit. So we are replacing the RB3 with another brand, that will hopefully work better.
I remeber when i installed RB3 on my Apex, the wiring is plug and play and the sled was running at notime, thats why i belive we have a bad unit on the Nytro.
Thank you all for the inputs.
/Svante
/Svante
tjc
could you exchange it for a new one? ir did you buy it used?
Does'nt look that way right now :/ we bought both units brand new last year but my friend moved and the Nytro was unfinished until i had time to help him out. So the unit is only old not used.
We will try the Powercommander 5 as it turns out the rb3 is discontinued. And the new unit is the same price as a true aftermarket ecu. For a piggyback system they are to pricy in my eyes.
I will update when the PC5 arrives so you know how it turned out.
/Svante
/Svante
Ok!
I installed the PCV unit yesterday and the sled runs. No problems this far.
Just wanted to let you know if any of you run into the samr problems in the future.
/Svante.
/Svante.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Thats good.Let me know how the pressure map works for you.
Dave
Dave
