gibb666
Just installed 114 1.45 megabites up the middle on my xtx, just wondering if i should add material to the tunnel protectors?
yox185
Yes, if you have an aftermarket exhaust. If your pipe is stock it should be ok, but why take a chance.
gibb666
That's what I figured, how much should I go 1/4,1/2"? Also do you do the ones on the heat exchanger or just where the exhaust is.
yox185
With all that room in the tunnel go as thick as you can. I had an issue with my studs hitting my Excell header. I added abut a 1/4"and it still hit. Then I went nuts and added a lot more, total is probably about an inch. No more hits. As far as the heat exchanger, I didn't do mine and I don't think it's necessary. Take a look at your exchanger you won't see any wear marks on the bars because the track never hits it.
gibb666
Sounds good, I have stock exhaust so ill probably go 1/2", thanks for the info. Is the skid hard to drop? Just losen the track and remove the bolts holding the skid in? Any tricks or tips.
yox185
gibb666 said:Is the skid hard to drop? Just losen the track and remove the bolts holding the skid in? Any tricks or tips.
http://www.ty4stroke.com/viewtopic.php?t=105148&highlight=xtx+suspension
gibb666
thanks again
- Poll
- 9K
