O.T. Flip-Up Helmets...Any Suggestions
Mighty Dukester has a slightly used Warrior Le that is set up well and only slightly used. Maybe you should talk to him!! LaLaLa
Which one are you referring to...the one his brother was "riding" or the one he put 12K miles on... :P
He doesn't have one with 12K but he has one with only 13k plus. It is just broke in for a puppy like you to ride. He has all the bugs worked out. OH what bugs? It never had any!
You would look real good on it :-o
vzoner said:
does anyone know if anybody makes a 4x or custom built helmet? If just one manufacturer would make a 4x, they would make a fortune. There has to be alot of riders with large heads.
Cat have some big helmets.
Several in our group have the Doo helmet. It is generally a good helmet except:
The heated sheilds are $150 and they have a slight draft when riding. You definately need a face sock. We all feel the slight draft is a real problem. The breathing device does plug up in cold weather but will stay fog free as long as the vents stay clear. You need a face sock even with the breathing device due to drafts.
We have one guy who went from the modular Doo to the $450 new Doo and likes it. It still needs a heated sheild for damp evening riding.
Dukester was wearing the Doo modular when he had the major fogging problem in Canada. At -45 degrees F the tubes would plug in about 20 minutes. He got frost bite taking the helmet off to defrost and clear the tubes.
