BigDog05
Since stock RX1's run fine on 87 octane, does running high octane gas show a lean reading on the a/f guage.
I ended up running 20 pilots at 2 turns last year to keep my a/f readings in the 14.3 to 15.3 range depending on weather conditions and elevation.
At home I'm just under 1000ft and where I ride in Pa is between 2200-3000ft elevation.
Last year I ran 93 pump with 103 VP oxygenated unleaded. I'd fill it with 103 at home and add 93 if we got fuel on the trail and cut the boost back a little.
But this sled sounds better, revs better and just plain feels better with
17.5 at 2 turns. Plugs look better, sounds crisper.
I'm running an innovative a/f and have changed sensors, did open air calibrations etc. And the readings are always consistant, no matter which sensor etc. 17.5's always go to 16.5-17+
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
TOOOO lean , you should see 12.5's at wot.
BigDog05
This is at idle, I'm fine at full throttle.
Probe location in exhaust stream ???
BigDog05
My probe is right past the turbo, and I have the Bender dual exhaust so there is at least 14-16 inches of pipe to the exhaust tip.
As a point of info, Justin at Full Power Performance suggested a 15 pilot at 2-2.5 turns. I never made it out of the driveway. Idle readings were in the 18'+.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
I agree with Hammer and think your idle is a false lean reading due to the O2 sensor location. I run mine in the baffle chamber of my Whiteknuckle Exhaust (just above where the pipes go in) and had similar readings. Even going all the way to 22.5 pilots @ 2 turns out on the screws it would still read 14s at idle and ran like crap.
After calling MPI and talking to Mac; he told me the readings at idle were due to negative exhaust pulses puling air back throught the exhaust pipes and baffle chamber. I have the 17.5s in it again and just live with the high 16+ idle readings with screws at 2 1/4 turns out. I have 1300 miles like this now with no issues.
Jim
Jim
BigDog05
That sounds very possible. I guess a better way to explain this is, the first year I had the sled, I was running a dual boost/egt guage.
My set up was: pilots 17.5 @ 2 turns, needles 1 notch rich, stock jets and adjust pitot jet as needed.
The second year I had the sled, the A/F guage became the hot item. I think I found myself sitting and looking at the A/F guage everytime I was stopped or going very slow.
Where I ride in Pa there are times when you may have to go for a mile or so thru the woods to get to another trail. With the 20's in, the sled just sounds and feels bad. I'm talking 5-10 MPH.
Also I'm running billet caps and T's and 2 lines from the intercooler to the carbs.
Thanks for the replies guys.
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Something doesn't sound right. My engine won't run at 16:1. I'm at 750 ft and ride at 1600 in northern Wisconsin.
There must be exhaust leaks drawning in fresh air or maybe you have enough misfires to make you think your 16:1. Misfires make the engine look lean as you have fuel and unburned air in the exhaust.
Stock Yamaha Apex's will idle at about 13.2 :1 maybe 13.5:1 over 14:1 is too lean.
