Oft big nuts
minytro
Hello all. I m just putting my skid back together. I'm installing a set of oft big nutz and axle. My issue is now I have a 1/4 inch of play between my rear wheels. I don't think this is right. Can someone let me know if I'm doing something wrong.
Did you order the kit for the stock wheels? Most of his kits ship for use with the 6304 bearings which is 3mm wider than the stock wheel's bearing's so if you did not specify why ordering i can assuming this is why!
Here is it from their website!
This axle kit was developed to replace the OEM axle with an attractive and durable replacement for the OEM Yamaha Axle, and utilizes 7" wheels.
The OFT Racing's axle kit is designed to use wheels that are equipped with 15mm wide bearings, such as OFT Racing's SS Billet wheels.
(we use a #6304 bearing that is 3mm wider, and a full grade higher than those found in most OEM wheels).
You may also opt to use your OEM wheels. (Please contact us for more info on this application)
We also offer you the option to run two or AN INDUSTRY FIRST THREE wheels between the rails!
