ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have a pivot risor on my MTX. Would getting an OFT relocator be of benefit? Just wondering what the difference would be.
mtdream
Pivot merely moves the handlebars....relocator moves the steering column, and changes the angle you will use the handlebars...
One is band-aid (pivot), the other is a solution....(relocator)
HIGHLY worth it to have the OFT Relocator
bholmlate
x2 what MTdream said. I actaully run a OFT relocater and RSI pivot riser on my sled. I used the pivot riser to make minute adjustments to position the bars right where they work best for me.
As MT said Relocator changes the angle of the OEM steering column into a more natural riding position. It is amazing the difference it makes by moving the column +/- 2 inches. There are few relocators out there but for the fit and finish i went with OFT racing. Its a little more but Its well worth the money.
FYI the OFT relocator, by moving the column +/- 2 inches it also rasies the bars +/- 1 1/2 inch up so you may / may not need a smaller riser.
What they said.
I run both.
I run both.
akvector
I only run the locator and it is perfect and like the rest said quailty and fit is superb!!!!
