S pump
- Nov 19, 2005
I have had my shock solenoid wire broken 3 times and it's getting old. I am going riding Thursday and was wondering if it is possible to manually adjust the EC shock compression dampening by removing the solenoid assembly and manually adjusting. Dealer is ordering another part for me nbut I dont think it will be in in time for next ride. FWIW, the shock wire wasn't correctly routed and made contact with the track. Seems to me common sense routing would save alot of problems. Kudos to Bruce at Pioneer. The range of adjustment and bottoming resistance is superb when the wires are connected.
Honk
I installed many more zip ties on mine thinking it would hold better. 1800 hundred miles and all is well. I agree, Bruces revavle with heavier spring is all the Apex needed! Mono works GREAT!!
