HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
hey i have a 06 gt and my rear shock quit working last year, i had already repaired wires once so this year i had skid out to do bearings so i just ordered new solinoid from shocktec and installed, put back togeather and still cant acess shock icon, checked resistance at plug under cowl going to shock, 5.5 ohms, checked fuse , good, have power to one side of plug, any other ideas?
HABS 1
- Oct 22, 2015
- corunna,ontario
also just checked other wire in plug under cowel , it goes directly to ecu, checked it for continuity, and is good , so my thinking is ecu decided to take a s---, on the shock function or is not reciving signal from ?? cluster switch?maybe im missing something simple?anyone?
HABS 1
- Oct 22, 2015
- corunna,ontario
would like to do more testing befor buying more parts ! im not giving up on the ecshock!!! any body?
Sp600
- Jan 19, 2012
- Southern Ontario
- 2008 Apex LTX GT
I too have the exact problem and wonder if it is the ecu as well? Can anyone chime in and with any other ideas?
HABS 1
- Oct 22, 2015
- corunna,ontario
i dont have another sled to try one on and have been looking for a used ecu but to much to spend just to try!! there got to be more tests oter than getting parts gun out!!
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
I'd have the shock rebuilt, could be something internally with the shock before you go tearing into the electronics.
HABS 1
- Oct 22, 2015
- corunna,ontario
was rebuilt and revalved 2 seasons ago but probally due for these shocks from what i read,but thinking u should just be able to plug solinoide in harness not even installed on shock and cluster or ecu should recognize signal, internal shock problem mechanical not electrical
HABS 1
- Oct 22, 2015
- corunna,ontario
am i right or wrong?
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
Yes.
Sp600
- Jan 19, 2012
- Southern Ontario
- 2008 Apex LTX GT
My shock has been newly rebuilt and new solenoid put in recently by Frank at Shocktec. The shock wire is good and have a new battery in sled now and still no icon. Not sure what else to do as I have checked everything else that Habs 1 did.
rwill2cruz
- Jan 23, 2015
- Sudbury, Ontario
- 08 GT LTX Anniversary
unplug the shock and without shorting put an automotive test light on the plug coming from the sled...ground clip to black and probe to other. Turn ignition on and the shock icon should show. If it doesn't check the fuse or for an open wire.My shock has been newly rebuilt and new solenoid put in recently by Frank at Shocktec. The shock wire is good and have a new battery in sled now and still no icon. Not sure what else to do as I have checked everything else that Habs 1 did.
HABS 1
- Oct 22, 2015
- corunna,ontario
I understand what u r saying will2cruz,the test light will provide same resistance as good solenoid,so therfor eliminating the harness going to shock and solenoid itself,but I have 5.5 ohms on meter at harness going to shock tested at plug by reverse lever,(new solenoid),it has power 12 volts plus ,that power wire goes directly to fuse so its good!and the other wire goes to ecu and has good continuity so its not broke,unless it routes through something else befor ecu,but from wire colours and looking at sled wiring scmatics im sure I tested it properly,but I will still try this anyway and repost,i also removed ecu checked pins and plugs,cleaned with electrical spray contact cleaner on both ecu and plugs and reinstalled,and-------NUTHIN!!
Blue_Blood
- Nov 3, 2015
- sarnia
- 2010 yamaha apex ltx gt
Hey got a few words on this one fellas my 2010 apex I had the skid out doing some work and I put it back in and ran the wire exactly how they said and it now doesn't work as well maybe just a wire or is that just wishful thinking ?
HABS 1
- Oct 22, 2015
- corunna,ontario
ok i did the test light check at plug comming from sled by reverse lever, ground on bk wire and probe to other, no shock icon, but also test light does not lite, should it?,if i put test light probe to other wire in plug and ground to frame it lights telling me i have power at plug, mabe the black wire in plug going into sled is broke somewhere if test light should light jumping both prongs in plug? please let me know
HABS 1
- Oct 22, 2015
- corunna,ontario
plug on sled by rev lever , one straight power from fuse other is brown yellow wire goes directly to ecu 100 percent forsure!! and has continuity to ecu plug , just tested,--- again,need to try another ecu is next step!!
