ohlins ec shock trouble
Turbor
mirabel,quebec,canada
Canada
sidewinder
i juste replaced my ohlins shock selenoid, checked the ecs fuse, and i still cant get the display on the gauge ( to get the display you have to press the center button on the dashboard right? just bought this sled and the wires where cut on the selenoid) the selenoid is new, the harsess is ok, what could it be then?
If you have a friend with an Apex you may want to try their ECU. I have seen two units with the same problem and they both were fixed by replacing the ECU. It seems when the wires get cut sometimes they short out and take out the circuit for the shock in the ECU and then the ECU acts like it doesn't recognize an electric shock is present though wiring wise everything tests okay. The ECU's are pricey so testing it with a known good unit is usually the first place to start. Any Apex/Attak CDI will work - it doesn't have to be off a GT as they all have the ability to have the electric shock. Hope this helps.
