daryl506
- Jun 2, 2010
hey guys anyone tell me if they ever have trouble with going to the shock adjust setting on the apex with the ohlins shock? i was out on the weekend and went to adjust the the shock and i could not get my dash to the shock setting. anyone ever had this happen???
quebec#1
Yes broken wire . It will reset itself to the middle setting.
My wire broke 3 times now it doesnt work at all a problem with internal cluster guage. Im leaving it alone.
daryl506
- Jun 2, 2010
I just had it off to change the spring out to a bigger one. It worked after that then this weekend not working. So it will reset itself in the 50/50 mark.??
quebec#1
Thats what im told !daryl said:I just had it off to change the spring out to a bigger one. It worked after that then this weekend not working. So it will reset itself in the 50/50 mark.??
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
hey darl
if you are handy it's a easy fix,
there is a connector near the shock under the sled if you remove all the zip ties you will see it,
disconnect the wire and remove it so you can take a look at it, it will come out towards the right side of the sled, remove the tape near the connector and in most cases that's wear the wire seems to break,
For some odd reason the wire insulator ends about 2 to 3 inches away from the connector causing the wire to break..
