ZR800EFI
Hey, can someone point me to a thread explaining how to change the oil on a Vector? I'm gonna help a buddy in a couple days and I've never done one before. I know it has to be easier than my Apex!!! Just not sure if I have to drain in a couple spots, ...
Thanks!
Thanks!
7phigyers
- Nov 25, 2007
inspection plate on underside of engine =filter and drain plug careful to make sure old o-ring doesn't stay on.Oil resevoir on throttle side ,after removing side panel.
05 RS Vector owner
05 RS Vector owner
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Much easier than the 4 bangers
Just like 7phigyers
said; The panel under the engine gives access to both the oil filter and the engine drain plug. Then remove the right side cover to drain the oil tank.
Just like 7phigyerssaid; The panel under the engine gives access to both the oil filter and the engine drain plug. Then remove the right side cover to drain the oil tank.
doc
- Jan 16, 2006
- SE MN
- 2015 Apex , 2013 Apex
Pour oil slowly or you'll have a mess !! Look for a small screw on spout , got mine at the local Case industrial dealer from a bottle of differential oil , made the oil fill a piece of cake !! Just go and ask a mechanic if they have one .
