bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
Does anyone know where I can get information on how to change the oil and filter on my 04 RX1 Warrior? The manual only shows how to change the oil. I also want to change the filter. Heard it was under the battery?
Thanks,
Al
Thanks,
Al
Honk
Take the carb box off, filter is under it. undo plastic plate in bottom of sled and drain oil. Do the gear oil too! drain is in the tunnel at bottom of the chaincase. Lotsa info on anything you need or desire, just look! Good luck!
