jmbones
When you change the oil and filter, how much total oil is required?
The manual says 4qts total over all but then it lists 3.2qts with a filter change. It also states at 2.1qts to the oil tank and it doesn't say to add anything else. Do I add the last quart into the oil tank or the inlet on the top of the motor?
