superbeast
i havea 07 rtx cpr turboed apex and i was out riding on saturday on the river and therewas a straight stretch so i gaver alittle about 110 i came into a corner and let off the thottle and it quit running i thought i maybe bumped the tether ( nope ) tried it and started right up so i thought must of been the tether ( the tors is bypassed ) then it died again then i seen it said code 30 on the screen so i got off and thats when i seen oil on the ground and on the side panel boy i was shitting at that time pulled the panels off looked around checked the oil just below the low line so i got towed home
tore it apart cannot find a leak anywhere no hole in the 1 line way down below the oilcooler was alittle loose but not enough to leak , the big bolthead on the oilcooler was alittle loose but it didnt seem to be enough and all the oil is down around that area oilfilter , oilcooler , e.t.c no whereelse look underneath no holes alittle residue from leaking down , put it back together part way put oil in and started it to look for any leaks and nothing no code , idles fine , runs fine but cant figure out where it came from ????
any ideas ??
ohyea thesled has like 200 miles on it and running 91 octane on low boost all setup by jeff simons
mike
any ideas ??
mike
tko47
I hope i'm wrong but if you had a little detonation the blow by will blow out the valve cover gasket check the half moon part of the gasket on the sides, it happened to me 4yrs. ago running 91 on 10psi on a stock motor, and the motor ran fine ,i thought i blew a belt but oil got on the clutchs. I hope I am totally wrong I'm sure you would have noticed oil higher up on the engine unless it blew out the backside
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
superbeast said:i havea 07 rtx cpr turboed apex and i was out riding on saturday on the river and therewas a straight stretch so i gaver alittle about 110 i came into a corner and let off the thottle and it quit running i thought i maybe bumped the tether ( nope ) tried it and started right up so i thought must of been the tether ( the tors is bypassed ) then it died again then i seen it said code 30 on the screen so i got off and thats when i seen oil on the ground and on the side panel boy i was shitting at that time pulled the panels off looked around checked the oil just below the low line so i got towed home
any ideas ??
mike
Call Jeff.
superbeast
well i think i got it it looks like the oil filter seal #*$&@ out , i clean that area up and start it up and thats where it keeps getting wet , the local yamaha dealer didnt a filter or oil for it ( there are realy BIG JOKE OF A DEALER )
i will let you know when i get it apart
