Maineland
how do you get the batery box out of the way.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Maineland said:how do you get the batery box out of the way.
From the FAQ under "Oil Change With Pictures". Click on this link for the document. Steps six through nine are applicable. Scroll down in the document and you will see pictures 6a through 9d showing the procedure.
http://www.ulmerracing.com/Complete.pdf
Maineland
I went there I have it all unhooked but batery box is welded on the top and still will not come out
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Maineland said:I went there I have it all unhooked but batery box is welded on the top and still will not come out
Here are some pictures of my battery box removed. Which welds are you talking about? The welds that connect the top rear of the "box" to the upper mounting bracket? Ulmer's pictures should show you exactly what to do. It is a little tricky the first time you do it but is not that hard to do if you have done it a few times.
I originally considered purchasing Ulmer's oil filter relocating kit (as shown in the link) but I have gotten pretty good at taking the battery box out and I like to take a good look at the steering linkage and electrical wiring once a year anyway.
ApexDriller
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
ApexDriller said:I leave the battery tray in...I just loosen it, push some wires out of the way and I'm able to slide my hand between tray and front of motor, filter comes off easy by hand.
I feel that the filter change it is a lot easier with the battery box removed. Especially if you want to do a good job of trying to catch the dirty oil with a rag and then doing a good job of cleaning the engine and the belly pan afterwards. JMHO
Maineland
thanks guys It is my first time with the filter. the picks really help thanks again.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Maineland said:thanks guys It is my first time with the filter. the picks really help thanks again.
You are welcome, TY is all about helping each other out. I assume that you were able to remove the battery box. Now that you have done it once it will be much easier next time.
Honk
two 14 mm bolts holding that battery braket in need to come out. follow the round shaft over to the frame.
