BURMAD69
Please help I have a 07RS Venture and an 07 RS Rage that are both putting oil into the air box, When the sleds are running its a steady flow of oil, I cant believe both would have a faulty crankcase vent valve. ANY HELP PLEASE.
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
- 2015 Arctic Cat ZR 8000 El Tigre
Sounds to me you have a pinched/kinked vent. There is a service bulletin published by Yamaha for this issue. When removing the air box and reinstalling, you have to make sure when reinstallng you don't pinch/kink the tube. I had the same issue on my '10 Vector.
BURMAD69
K thanks I'll check that
BURMAD69
well its not a kinked hose because it does it with the airbox removed, oil comes out the large hose that attaches to the top of the air box. Guess I'll have to do more research
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Over filled the oil reservoir after an oil change?
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
X24strokeluvr111 said:Over filled the oil reservoir after an oil change?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
IAVECTORGT said:X24strokeluvr111 said:Over filled the oil reservoir after an oil change?
X3.
When checking your oil, are you screwing the dipstick all the way in to see your level?
Just rest it on the top of the fill hole and take your reading there. If it is in the upper hash marks your good to go.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Irv said:IAVECTORGT said:X24strokeluvr111 said:Over filled the oil reservoir after an oil change?
X3.
You had me wondering Irv because I would screw in the stick to check my oil level. I just checked my manual and you are right! Doing it "my way" would have one adding a bit less oil to the reservoir. I'm going to check my oil level later to see where it's at.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
I had the same issue on an 09 vector! Over filled reservoir and oil filling the air box. Remove some oil and youll be good
lynnmor
- Feb 16, 2011
BURMAD69 said:well its not a kinked hose because it does it with the airbox removed, oil comes out the large hose that attaches to the top of the air box. Guess I'll have to do more research
Just to be clear, did you follow the hose that goes down the right side of the engine?
BURMAD69
Not over full on oil, and yes I followed the hose all the way down to the side cover,however I'm wondering if thats a check valve that the hose connects to because I cant blow through it.
