roostinraptor
the top front mount on my oil tank snapped off. is there any aftermarket tanks out there? or anyone got one from a partout they eant to sell?
or is my best bet to have a piece of aluminum welded to it and drill a new mounting hole?
Stoli
PM Moto or Scmurs - there is an aftermarket option - I dont know much about it and do not want to post a bunch of rubish...
There is a guy on here that is making aftermarket tanks, I forget his name but he's out there, personally I would fix the stocker, they are so light and do the job (plus its paid for).
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Ulmer sells an aftermarket Nytro trail tank that holds 10 gallons..Check with him..
Oil tank not fuel tank......TotallyNytro said:Ulmer sells an aftermarket Nytro trail tank that holds 10 gallons..Check with him..
shadow44
There was a guy on HCS in the Nytro section selling a heavy duty oil tank...not sure of who.
Sledhead162 has oil tanks for sale on HCS under Nytro ~ I believe the second page.
sgilbert
it s actually built by mack, also uses 2 filtersTotallyNytro said:Ulmer sells an aftermarket Nytro trail tank that holds 10 gallons..Check with him..
Nikolai
Mine broke off two seasons ago. I made a new one and riveted it over the old one...still using the same tank.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
I repaired my stock one. just welded aluminum over the the original brackets and drilled new holes. been fine ever since. but get it fixed fast as my lower hose was rubbing on the frame and i lost all my oil...
mach9
While your at it, check your radiator brackets too.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
X2 mine are cracked also. i just put temporary fix of bigger washers in there to finish the season last year. will weld them up this year.
bradthebest
i just tig welded mine and the bottom of it aswell when i was at it .
that was tricky doing the bottom by the seam .
