welterracer
This is my second oil tank.. its cracking and leaking again..
Is there anyone making an aftermarket one that is stronger?
motohd66
maybe mpi would sell you one?? i have heard of this happening but we have had 6 4-strokes since 03 and i have never had any issues, where are they cracking?
welterracer
Near the bottom bolt on the front side..
It starts with a small leak
niko
once I get my tig welder I'm going to be making one from alloy. Will let know know how it goes.
Yamahammer485
You should put up some pics?
There must be some logical reason why this is happening.... I havent heard of this happening elsewhere either....
welterracer
There were a few people last year that had the same problem
Its because there are only 3 mounting points to hold that tank and the tank holds 2-3 qts of oil, thats alot of weight on it..
motohd66
i would still check with mpi, their tank is alot thicker and it can be polished to a shine!
sgilbert
rubber mount, the only answer. I eventually rubber mounted everything including headlight and taillight on my stroked ironhead sporster. never had a problem again
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I have a new one for sell in the box from yamaha yet. Sorry just had to put that in i've had three new ones on my 06 rtx.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
If you need one will sell it for alot less then yamaha
