Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yamaha GYTR front shocks
Hey guys just looking for advice on what oils to use in the phazer...My mechanic swears by Amsoil fully synthetic 4 stroke motor oil and chaincase oil..And the yamaha guys at the dealer are obviously saying stay away from those and use the semi-synthetic yamalube, aswell with yamaha lube chaincase oil. The question is.....which one is better?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I'd go with Yamaha the guys designed your sled to work with it.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
food for thought....my mechanic also said the synthetic motor oil would get me close to 5000-7000k per oil change which i thought was crazy.....I havent changed the oil yet by my yamalube semi synthetic is looking pretty black when I checked the dipstick
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
My F150 gets almost 16,000km (10,000mi) between oil changes on a semi synthetic.
That said maybe if you are putting on 5000km per year it's worth it but for me I don't put that much on and just change the oil once a year in my Phazer.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
I too would suggest staying with Yamaha. Particularlily because this is such a unique engine/design. With change intervals we have even with sythetic it will get, "look", dirty/dark and Personally I wouldn't push the oil that long anyway.
What i've done in the past with everything I own with the exception of my eXcursion, is change the filter on every second oil change. My race quad, I change every 3rd ride (practice or racing) and I've just used crappy tire Castrol 4stroke oil. But the sled, Yamalube. I've seen 1 post with engine failure and know of one locally (slapped turbo on and didn't follow through with other mods that should have been done). IMHO, I wouldn't mess with what works.
I saw in another post of yours, your grommet looked melted. That may just be a reaction between the type of case oil the PO used or topped off with.
Learnt that at the Bio-Diesel plant I worked at for many years. Viton, EPDM, rubber ect ect all have certain break down limitations. Such as the gaskets on our machines. Depending on what their made of, maybe a lubrication additive in the say, Amsoil, may not be compatable with the gasket. Food for thought.
ATV PRO #11
- Jan 22, 2011
Ur pushin it Voda!!My F150 gets almost 16,000km (10,000mi) between oil changes on a semi synthetic.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Ur pushin it Voda!!
That's right from Ford. I just follow when the truck tells me to change my oil. It adjust based on usage, temperature, towing, etc.
I've seen some test of oil from truck that high and the lab results predicted the oil would be good for another 5000km. Today's motors run a lot cleaner than they used to.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Good point. My other hobby is British cars and certain brake fluids will turn the seals to mush.
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
From experience with my rx1warrior use the synthetic yamaha lube
https://www.yamahapartsandaccessori...ith-ester?b=Engine+Oils&d=30|30&dealernumber=
With the semi-synthetic it would start to -30C fur with the full sythetic yamah lube I have started it down to -40C not plugged in. Also it is safe for any wet clutches, and seal in your yamaha.
ATV PRO #11
- Jan 22, 2011
You will get every answer under the sun on this one..And the yamaha guys at the dealer are obviously saying stay away from those and use the semi-synthetic yamalube, aswell with yamaha lube chaincase oil. The question is.....which one is better?
Bio-Diesel turns many to mush!! Best penitrating oil I've ever used, carb cleaner, oxidation remover ect ect. I still have some I use to this day.Good point. My other hobby is British cars and certain brake fluids will turn the seals to mush.
Blackstone out of AB or MB Hydro Lab in Selkirk? I've used MB Hydro lab to test for lubricity many times. Just razzin on the pushin part. I know many that don't maintain and push things even further.......crazyness sorry
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
No worries I don't mind a bit of razzing. I guess I'll see in a few years how it worked.
The tests were from Blackstone, but not my sample I've just read about them else where. Didn't know MB hydro has a lab that does that.
ATV PRO #11
- Jan 22, 2011
We took our fuel to Walkeim at Selkirk Lab. To confirm they do used oil I can't, but they did test our fuel to meet d6751 requirements. SUPER STRICT.No worries I don't mind a bit of razzing. I guess I'll see in a few years how it worked.
Would be the ulitmate test to answer Devin's question at the end of the day.
I know racers that swear by Lucas, Amsoil, Yamalube ect. With this particilar sled, i'd stick with Yamalube.
ATV PRO #11
- Jan 22, 2011
https://www.yamahapartsandaccessories.com/shop/product/details/0w-40-snowmobile-full-synthetic-with-ester?b=Engine Oils&d=30|30&dealernumber=
Interesting link. Yamalube uses "Esters" for full synthetic. Bio-Fuel is an "Ester" until it manipulated to meet d6751. Then you call it Diesel. Either way,
It's lubricity factor blows the doors off anything it goes up against.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Very good points from all of you. I think with oils it comes down to opinion....Im not too sure if there any phazer motor failures on this site related to fully synthetic oils.
I do know my mechanic as been doing his job for 20+ years now and he runs his amsoil fully synthetic in all of his yamaha toys including the 450 race quads..
ATV PRO #11
- Jan 22, 2011
Where ya from Devin?Very good points from all of you. I think with oils it comes down to opinion....Im not too sure if there any phazer motor failures on this site related to fully synthetic oils.
