smitdog55
About 3 kms from home sled running along fine then all of a sudden quit after putting on the brakes any idea, wont fire back up, bad gas? Just put power commander v on it and clutch kit and airbox, relay?
unplug the power commander just to make sure the box didnt go bad.
smitdog55
Well that was fun! Removing fuel commander by moonlight then finding a flashlight after cell died! Either a wire came loose or the commander quit but it fired right up when i put original back on! Thanks for your help!!
yamahahaapex
depening where the box is located on yours I found out that mine got some snow in the ports somehow and it took it out. After I bypassed mine it worke and once i dried the box up it did as well. The pcvs seem to have better usb ports and I id mine further inside to prevent it from getting wet again
smitdog55
Found the issue after plugging it back in, the bolt that holds the ground to the frame fell out therefore didnt work, im going to blame myself for that one! Likely a 10 cent fix!
I would rathernfound my mistake then chasing somebody else's...lol
