Ordered CR10EK's got CR10E's, is this the same? Is it okay?
02xtreme
Ontario Canada
I have a feeling the CR10E's have 1 electrode and the CR10EK's have 2 electrodes. Too late to return them, can I use the CR10E's??
Re: Ordered CR10EK's got CR10E's, is this the same? Is it ok
The E's have one and the EK's have two. But they should work fine. If the plug is of the proper specs it will work. It may not last as long. If all the specs of the plug, heat range, thread length, diameter, and core material are the same it will work just the same. Your plugs can't jump a spark to two prongs at once anyhow.
