OTHER HAND WARMERS ISSUE on APEX GT
Albany, New York area
Check your hand warmer graph setting, run this easy test.
After having set warmer to high the normal default is for the display to switch to display the fuel level.
Ran sled on jack stand at 5000 RPM and felt the warmth ( the littlte that there is) getting cooler, hit the warmer button and noticed that the heat level on the graph display goes back to midway.
Did test several times with the senario occuring each time. This is a recurrent happening, it keeps goes from the high setting back to mid way every time. I'm not sure this is on my sled only, CHECK it out.
My Apex GT does the same thing and I just keep moving the setting up. Have not talked to my dealer about it yet. Sled is going in for new rear shock next week and I will mention it to them then. I'll let you know what they come up with.
