onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
http://www.youtube.com/watch?v=HWUzoTf47co
BRET you are the best Driver as far as we are concerned you showed your skills this past weekend at Haydays with heat after heat OUTSTANDING JOB and from all my CREW as always, Justin, Jen, R DUSTIN, Jeff Hines,
Justin is and has did great Job Videoing these events Great Job Son... I have lots and lots of haydays videos The Next video I will do is the KING OF THE TRAIL keep watching for that in the next few days..
this NEW OSP sled is one our best builds the new chassis has the center of gravity 8 inch's lower then the past OSP chassis. we are in development of a new power plant that everyone will see at Hastings grass drag. this current engine is the same as last year STOCK crank, pistons, head, and bore, (there is a lot of hearsay out there but this is mostly stock parts, we build and sell this engine with a good core for 5000.00 built ready to install. but that is only 1 part of making big HP, we also sell the turbo kits and standalone to make over 600 HP, you may say what you want this is the true story we run 10 pounds when we launch, 30 pounds that ramps to 42 by the end of the track, listen to the videos , our sled was out of gear hitting the rev limiter every pass, (on race day I will not make changes) so we had to just deal with it.). we are 100 pounds heavier then everyone else in the our class and still run the numbers...
If you haven't made plans to go to Hastings grass race you should !! you may just see the first sled to go 150 MPH in 500 ft see you all there...
I want to tell everyone that we have worked close with Mark at STM to grab all that HP his newest clutches and New fly weights are just unreal, we had NO belt issues using stock SKI DOO belt ( for the length..) we are doing 1.06 sixty's spinning, the Hastings grass track has much better starting line I think you will see some under 1 second sixty foot times.. Great job on the new clutch and weights Mark STM..
WOODYS studs are the best ( the Haydays track is full of rocks ) and our studs took it they need a few replaced and sharpening for race day and made round after round and still are good enough for the next few races we have left this grass season .. thanks Rick and Larry for a great product..
NO limits racing Jimmy wentworth this is the greatest man alive I love you man... can wait for hastings.
our NO limits KING OF THE TRAIL sled is rocking and only has 2 days of testing, we have developed turbo kit for your stock Nytro with standalone EFI with data logging I will tell you more about this on the king of trail post I do, this is STOCK ALL STOCK just STUDS, RODS, and special Head gasket we had made, our turbo kit and standalone this sled ran 4.25 127 and129 most passes at haydays with really bad 60tys footers 1.4 we will get this tested some more by hastings there again you might just the first 3 second pass with a trail sled... see you all there...
I will have more videos from haydays asap...
Jim
Jim
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
WOW!
Great job big Jim
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Awsome..... Great Job guys....
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Thanks for adding this video clip. AWESOME runs!! This is now the only class that interests me. I was there last year to see these sleds run. Being there is breathtaking though the first time you see these machines run. It's like they are shot out of a cannon. Better plug your ears too when the waste gate snaps after they let off the throttle. I missed this year and after the mega traffic jam am glad that I did. This is all I needed to see to spark my fire.
