Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Using 1.63" studs with 1.5" chisel would give you approximately 3/16" height difference.
I'm one of those guys that definitely avoids harsh conditions. Concrete & blacktop are very hard to avoid, crossing streets, parking lots, fuel, etc.
Do chisels accelerate wear on clutch components & belt life?
Anyone try these yet? Or similar product.
Turboflash
- Mar 18, 2019
- Southern MN
Aluminum anything won't hold up on normal/usual trail. They're made for drag racing/speed running on good snow. Not very good on ice/super hard-packed conditions either.Using 1.63" studs with 1.5" chisel would give you approximately 3/16" height difference.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, I kinda thought so. Better to ask the pros. I honestly like the concept. Sure would help if they were made from a more durable product. But then, there goes the cost of goods. $6ea turns into $30ea. Thanks, turboflashAluminum anything won't hold up on normal/usual trail. They're made for drag racing/speed running on good snow. Not very good on ice/super hard-packed conditions either.
Doc Harley
- Oct 17, 2016
- Here & there
So in getting back with the p1s....haha. it seems there are two versions, that I would consider. 1.25" & 1.5"
1.25" would allow Appx. 5/8" of stud penetration before the chisel made contact.
1.5" version would be Appx. 3/16"
Both using a 1.63" stud.
Note: please do not comment in regards to plastic backers you see in pic. I know.
DooZ
Try these https://snowstuds.com/products/terminator-series-studs or any push thru chisel. If your hell bent on real traction, try these bad boys https://www.facebook.com/6710387662...d-engineered-to-obsolete-al/5041901059167095/
Doc Harley
- Oct 17, 2016
- Here & there
The P1s have a very unique & special ability. They can be installed and removed without taking the stud out. Which is an extra step and more than 2x the work.Try these https://snowstuds.com/products/terminator-series-studs or any push thru chisel. If your hell bent on real traction, try these bad boys https://www.facebook.com/6710387662...d-engineered-to-obsolete-al/5041901059167095/
You can quite frankly trail ride to an event and have them in your tunnel bag along with a driver of course.
30min to install 96pc?
Turboflash
- Mar 18, 2019
- Southern MN
I tried those steel chisels for a few years. When new, they work great. But, they get dull fast and wear shorter. Not suggested for trail use. Anything goes for racing cuz your on ice or good snow.Try these https://snowstuds.com/products/terminator-series-studs or any push thru chisel. If your hell bent on real traction, try these bad boys https://www.facebook.com/6710387662...d-engineered-to-obsolete-al/5041901059167095/
What? They would work great if you could carry your sled across the pavement to fuel it up! Comm'on guys toughen up! Lol At $6 a stud that's only $1200 to stud the track! You only have to re-stud every other weekend!
Doc Harley
- Oct 17, 2016
- Here & there
Word....What? They would work great if you could carry your sled across the pavement to fuel it up! Comm'on guys toughen up! Lol At $6 a stud that's only $1200 to stud the track! You only have to re-stud every other weekend!
