MikeAttakNYC
i just redid my dads 06 apex gt with a flamed windshield, red hand guards, a new seat cover is in the mail along with red exhaust covers and red retro decals from arcticfx... i wanna paint the gray plastic screens red.. any ideas so it wont chip away and how to take them off and put them back on with out breaking them.. thanks
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Any auto body supply shop should have a product made by SEM that is an adhesion promoter just for plastic.
RTXgary
I used Rust-Oleum plastic paint. I painting mine a year ago and have not had a problem with chipping or peeling. The paint is made for plastic. Home Depot or any hardware store that carries Rust-Oleum should have the product.
AttakMax
- Feb 4, 2007
- Corner Brook, NL, Canada
- 2013 Nytro XTX 1.75 Supercharged
2007 Attak 144" ZX2
2002 SRX 136" Mono
I used the Fusion paint for plastic. I painted my grills white where my Attak is the blue and white color scheme. Paint has held up very well and it does a nice job. Many colors to pick from. The screens are very easy to remove from the inside of the panels. Good luck!
Mikecam
Make sure you use a plastic primer (rest-oleum specialty plastic primer) and the above paint and you will be fine. Light coats are also very important.
Metallicat
I used Killz primer in a spray can, as recommended from my local hardware store, and then Fusion paint. I painted my vents last spring and the paint is still pliable and does not crack nor does it chip when you flex the vents. I flexed the side vents pretty good recently just to see if the paint was going to crack on me or not. I first tried Rust-oleum but didn't like the shade of red that it produced and found the Fusion red to be a better match to my red a-arms and graphics. So in reality I have primer, rust-o-leum red, and Fusion red on top and haven't experienced any problems so far. The Killz primer really sticks to the plastic and makes a great base to paint on top of.
MikeAttakNYC
Thanks I'm gonna give the rustoleum a shot this weekend
**sj**
I also did the rustoleum plastic paint...textured black
Rove44
i used rustoleum primer and white krylon paint i roughed the screens up a littlle then used very light coats. I can't figure out how to post pix on here sorry
vote4pedros
If you want durability against stone chips and what not.. make sure to clear coat the paint when finished. And you won't have any chipping either!! Dupli color makes a decent clear coat found at any canadian tire.
