parking brake adjustment on 07 Attak
01and02srx
Grafton Mass
I need some input on my 07 Attak the parking brake does not hold even with the cable adjustment all the way out???? I dont see any major adjustments that can be made! Any help?? Thanks
You also need to adjust the brake pads; it's the locknut and bolt in the center to the brake pad, adjust pads so the clearance between the pads and the rotor added together is between .060 - .080". It works, just had the same problem. :Rockon:
If the adjustment doesn't work...
Did you drive with the parking brake on? I'd bet that the inside parking brake puck is gone. Take a look with a flashlight. The pad material is only about 1/16" thick even when new.
If you buy a new set of pads, you probably only have to replace the inside pad. then you'll have a spare for the next time you forget the parking brake.
Ask me how I know... ;)!
