jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
What should one expect the RPM to increase with stock clutching for the Attack /Apex after 200-500 miles of breakin ? Curious if it bumps significantly or not. tx
Turk
Tech Advisor
On my 06 Attak last year i saw rpm increases twice. Once was at about 200 miles & the next was at about 800 miles. I was running aftermarket clutching & all of a sudden rpm,s went up about 300 & I needed to add more weight to the primary. It happened twice at the above mileage intervals.
jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
RPM Increases as motor breaks in
By stock- I mean "you do not change anything to your stock clutching calibrations during the breakin period."
Per Turk I understand the RPM, will jump at least 300 RPM, afte 200 plus miles, if it baselines at 10500RPM and after breakin (200 plus miles) its pulling 10800 RPM question then is whether the motor is still in the optimum power band ? or do you need to add pin weight to bring her back?
APEX1k
You would add tip weight to bring the peak rpms down.
Turk
Tech Advisor
With stock clutching it hit 10000 rpm till 200 miles. rpm,s then crept up to 10,200 ish. At 800 miles i hit 10,700 on perfect conditions with stock clutching. I probably changed clutching combos 2-3 times a week just to keep myself honest.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yup after 200 miles on very hard packed road,with a bare track it would run up to 11,000 sometimes. all stock no studs.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
How much rpm loss would be seen with 192 studs?
- 9K
