Phazer idle RPM
burlyviper
Ottawa Lake MI
2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
Hello,
I just removed an aftermarket exhaust and fuel commander from my 2008 Phazer GT and it is now stock. It idles at 1200 RPM once it is warmed up. Is this the expected RPM level? Thanks.
Should be 1700+- 100. I run mine around 1800+. Gets rid of the pause or wanting to die symptom when blipping the throttle
How do i adjust the RPM? Thanks.
On the clutch side, near the the shock, there is rubber plug. Pull the plug and the idle adjust screw is behind it. Plug is about1/2” round.
