phazer mcx turbo - oil in exhaust and leaking line?
TRUTH
Wisconsin
Hey guys, I have an 07 mtx phazer with an mcx turbo. Oil is leaking where the muffler mates with the turbo and leaking heavily from the oil line under the motor. It leaks at idle. What could be causing this? Beyond needing a new oil line, what would cause the leak at the turbo? Possibly the crankcase breather? Thanks, Frank.
Sounds like the seals on the turbo may be toast if it's leaking into the exhaust. Pull your intake off to and see if there is oil on the intake side of the turbo as well
