Phazer Mnt lite Clutching?
Tbyrd
SW Alaska
I hopeing to find someone out there that has done some changes to the Mnt Lite clutching that saw some improvements? I have an Excell exhaust and some bullseyes installed and seems like a little clutch work is needed. Any help or suggestions would be appreciated. :yam:
WOT should be around 11,500 - 11,750 Max.
Higher then that consider an Ulmer clutch kit. $115.
-Steve
I'm not so sure the ulmer clutch kit is the appropriate solution? My Mnt. Lite seems to overrev off the start and then my wot is 11300 to 11400. I was thinking a little higher rpm engagement for when its under a heavy load would be good. Even a little quicker backshift might be nice? Any feedback would be appreciated.
