sxmatt
Does anyone know how to adjust the couple blocks on the rear skid. It doesn't look like you can move the block forward or rearward to change the coupling point. Do they adjust with different size plastic blocks??
Any insight would be appreciated..
Matt
Matt
monker
They don't have 'blocks' but round 'stoppers' instead. The only way do adjust would be with a different diameter. It may also be possible to use blocks from one of the other manufactures. I guess time will tell.
cdnredline
There are four round stoppers on the rear coupler (they look like rollers). The ones on the GT are definately a large diameter (coupled more...less transfer) than what's on the Mtn Lite. These were on the true prototypes we saw three weeks ago. Maybe someone who is out riding some of the machines now can comment as these units should be pre-production models (closer to final specs).
Phazer dude
suspension
Does anybody know if the Phazer GT has tough enough suspension to go off jumps, and get roughly 5ft of air?????
