Pioneer Performance Revalve
tkuss
Platteville/Three Lakes, WI
Anybody get there rear shock revalved on their phazer. I have an 07 FX, looking to revalve with pioneer since I have had a good experience with them in the past. Anybody have pioneer or another company revalve your rear shock to make them better?
Also how hard is it to take the rear shocks out when the skid is still in the sled.
Anything has got to be a big improvement over stock.At least in my case it was.Shock easily comes out if I remember right the biggest pain is the lower one if you have 08 update you have to take the cross shaft bolts out because the wheels wont let bolt come out all the way since there are no holes in the newer wheels.Gearwrench makes job easier also.I think I also took the coupler blocks out to get it back in.
i had my bos revalve mine and it made a huge a HUGE differance. hes done a few others too. plus hes like half the price as hygear or pioner. like 45 a shock plus shiping and parts. he mostly does polaris shocks such as fox, ryde fx, and walkers. thing is KYB valves are real close to ryde fx high flow valves other then they have slots in the valve tops insted of bleed holes. same concept but harder to regulate.
a revalve and a new front track spring made a 10 times better ride
I had Pioneer revalve both rear shocks in an 07 FX, looking for a more aggressive setup. The shocks had improved bottoming resistance and the clicker had a wider range of adjustment, but the shocks rebounded too slow with the stock torsion springs, even when set to hard. With the race springs and overload spring adjusters, they worked well.
when my boss did mine he speed the rebound up around 30 percent made a big differance on thoes long straight aways where the bumps just get deeper and deeper farther u go.
