RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
During a long ride my sled developed a plastic sounding ticking coming from the right side of the sled towards the front. It's really noticeable at about 15 mph and as you get on the gas it eventually disappears. And it's not the cam tensioner as I replaced that last year. I went to look at my track and found the middle rear idler bearing missing so I replaced the wheel and added a 4th wheel in the rear plus put on new hyfax. I took it for a ride and the ticking is still there so I noticed the plastic tips on the front of the rails were loose from the rivets wearing. Would it make sense this is where my "ticking" is coming from. Also checked the chain case and adjusted the tension but the noise is still present!
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Yup! And if you don't watch them closely, the rivets will eventually fail and the caps will fall off........and that opens the possibility of catastrophic track failure. I lost a couple of them off of my RS Nytro so my mechanic finally drilled small holes in the rails and reinstalled them with Loc-Tite'd bolts. Now they're not coming off unless we really want them to. Good Luck!
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Thank for the response I thought I remember this happening on my old skid too!!
darv
- Aug 9, 2005
- 08 Apex 40th LTX
drill the rivet out replace with 5x25mm bolt with lock nuts and fill with silicone.
smalltownpower
i'm doing rail caps on both of our 2010 vectors, already have 5x25mm bolts as my dealer suggested instead of rivits. is the shaft for the limiter strap a common size that i could put 2 idler wheels on it to prevent rail cap wear?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
Funny you mention that. I just noticed a ticking yesterday. I fixed a bogey wheel and took it for a test ride. While riding I heard the ticking sound at slow speeds. It's my wifes sled and I don't ride it much so I'm glad you mentioned it. I'll do it today before we head out tommorrow for a ride.
theCATman
- Feb 19, 2007
- WI
- Yamaha
darv said:drill the rivet out replace with 5x25mm bolt with lock nuts and fill with silicone.
X2 on this. I did the exact same thing to my '06 Apex.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
Is that the chain case?
What do you think caused that?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I am thinking somehow the bottom gear bolt became loose and pounded itself thru the side of the case.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
I checked the 2010 Vector LTX and there are 2 rivets holding the tip on and they don't look loose. I left them for now. My Attak had only one rivet and was loose. Put bolts threw of course.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
that's a common problem there is a better bolt lost part# make sure you use loctie when you put it back in
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
RSVECTORFREAK said:Well I guess it wasn't my plastic tips making the noise after all!![]()
Ouch!
Sorry to see RS, hope you can up and running real soon
Mikedom
The key to making those tips stay on and not wobble is the silicone. Great tip for the tip.
