Kren
yamaslob
Last weekend i saw, a f5 with a broken rewind, a blown up zr900, a zr580 and a mxz700 with black smoke comen out the engine, needless to say ive never seen a 4 stroke broke on the side of the trail.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
What was the problem with the sled?
Kren
multiple things....
something was burning real bad for awhile...adjusted the belt and got better...issues with the rear suspension....and probably the biggest issue is it shakes real bad. I guess its a problem since last year with the model but they have not figure out how to stop it. Vibrations right up thru the steering column....and this is the 700, likely worse with the 900.
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
Sounds & looks like the guys I ride with 2 cats, 2 doo's, 1st cat blown motor, 2nd cat, dealer preped sled wrong throttle cable came off, 1st doo, oil pump failure, 2nd doo oil pump failure and blown rear shock. MY YAMAHA no problems..
RX1Jim
It would be easier and less embarassing for the Polaris riders to remove the hoods at the beginning of the season. That way it will be faster to work on the engine and clutch.
VectorER
Sorry to tell you guys but Yamaha has problems as well. I was broke down on the trails last Saturday night with a broken jackshaft (RS Vector). According to my dealer they were not notified by Yamaha Canada of the "Service Bulletin". What a joke, service bulletin! I think a broken jackshaft is a recall.... Anyway, apparently I am the one who brought it to their attention. The dealer did fix the problem under warranty but an apology is not enough for getting stranded 120kms out in the woods. I guess you find out how valued your business is when all they say is sorry you had to travel 200km's to pick you sled up! Planning on purchasing a new sled next year, not sure if it's going to be a Yamaha this time. Too bad if they loose the business due to customer service!!
All the manufactures have their problems, Yamaha included!
Tom-RX1
Hmmmmmm I wonder if this could be a bashing thread .
Tom-RX1
Tom-RX1
- 38K
