Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Just curious if anyone has tried them and if so, with what results?
Of all the ski threads/posts I have read I do believe I have heard of anyone running them, just curious why?
ahicks
I mentioned it once early last season when somebody else asked. I'm running them ('05 Fusion I think?). They're extremely aggresive compared to the stockers with no other changes (ski swap only, prior to adjusting to compesate). I ended up taking a BUNCH of weight off the front end - but that could easily have something to do with what I have going on in back. There is no hint of pushing, ever, anymore. I can now slide the back of the sled around, kinda, a lot of the time. Before, trying to do that was hopeless. I would encourage you to try it if you have a pair laying around. The bumpers I used were from SlyDog - but I'll bet there's a better fit out there somewhere. Mine were a challenge, could still use a thicker shim in back I think? Coming up with a set of those will be the hard part. Please post if you find something!
This past season probably not the best example of prime conditions to try them out in, but I'm pretty sure there is nowhere near the amount of snow coming out from under the front of the skis that's blowing back over the top of the windshield either. These seem to have much better flotation/control up front. FWIW
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
ahicks said:I mentioned it once early last season when somebody else asked. I'm running them ('05 Fusion I think?). They're extremely aggresive compared to the stockers with no other changes (ski swap only, prior to adjusting to compesate). I ended up taking a BUNCH of weight off the front end - but that could easily have something to do with what I have going on in back. There is no hint of pushing, ever, anymore. I can now slide the back of the sled around, kinda, a lot of the time. Before, trying to do that was hopeless. I would encourage you to try it if you have a pair laying around. The bumpers I used were from SlyDog - but I'll bet there's a better fit out there somewhere. Mine were a challenge, could still use a thicker shim in back I think? Coming up with a set of those will be the hard part. Please post if you find something!
Thanks, I'm currently thinking about some plastic ski's off a 2010 Polaris Shift?
Not sure on fitment or if any other parts will be req'd though?
If they are not going to fit or work very well then I think I will put them on my 95 XLT SP?
ahicks
They'll fit the Polaris easier than the Yammi. As mentioned, getting them to work on the Yammi will require that you come up with something to use in place of the stock rubber part that holds the skis level when ther's no weight on them?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
ahicks said:They'll fit the Polaris easier than the Yammi. As mentioned, getting them to work on the Yammi will require that you come up with something to use in place of the stock rubber part that holds the skis level when ther's no weight on them?
Thanks for the info, maybe I'll just put them on the XLT and not worry about the Vector until I at least try it?
From what I gather, most like the Kimpex Arrows the best for trail riding?
