MOTOWN SPEEDFREEK
2000 grit wet sandpaper and then mothers.
Used to be a 'Never Dull' user up until i discovered 'Mothers' stuff couple of month ago...
Thanks for the PLEXUS input, i will give it a try.
looking4speed
I used 3 polishing compounds with a buffing wheel on a drill motor.After that I used Mothers.The tunnel bumper and exhaust tips look like a good chrome job.The intercooler and charge tube look just as good.Still need to do the front frame.
BURMAD69
Auskins
where is Cubby on this post???
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
SPEEDFREEK said:2000 grit wet sandpaper and then mothers.
Do you actually wet the sandpaper/tunnel or just use the wet sandpaper alone?
MOTOWN SPEEDFREEK
lots of elbow grease, not mine though!!!
MOTOWN SPEEDFREEK
RX1MPete said:SPEEDFREEK said:2000 grit wet sandpaper and then mothers.
Actullay wet the tunnel!
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
SPEEDFREEK said:lots of elbow grease, not mine though!!!
OK, I will do the same as you...I'll get my wife to do it.
MUSTANG1
- Oct 6, 2005
- Canton, MI
- 2016 VIPER L-TX-LE BLUE
Where did you guys get the "never dull"??
