MOTOWN SPEEDFREEK
2000 grit wet sandpaper and then mothers.
Used to be a 'Never Dull' user up until i discovered 'Mothers' stuff couple of month ago...
Thanks for the PLEXUS input, i will give it a try.
looking4speed
I used 3 polishing compounds with a buffing wheel on a drill motor.After that I used Mothers.The tunnel bumper and exhaust tips look like a good chrome job.The intercooler and charge tube look just as good.Still need to do the front frame.
BURMAD69
first I used fine rubbing compound followed that with Mothers aluminum polish, followed by miracle wax, everything looks like expensive chrome, Tunnel,Tie rods,Rear bumper,Clutch guard,Ski buckets
Auskins
where is Cubby on this post???
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
SPEEDFREEK said:2000 grit wet sandpaper and then mothers.
Do you actually wet the sandpaper/tunnel or just use the wet sandpaper alone?
MOTOWN SPEEDFREEK
lots of elbow grease, not mine though!!!
MOTOWN SPEEDFREEK
RX1MPete said:SPEEDFREEK said:2000 grit wet sandpaper and then mothers.
Actullay wet the tunnel!
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
SPEEDFREEK said:lots of elbow grease, not mine though!!!
OK, I will do the same as you...I'll get my wife to do it.
MUSTANG1
- Oct 6, 2005
- Canton, MI
- 2016 VIPER L-TX-LE BLUE
Where did you guys get the "never dull"??
