stgdz
- Mar 27, 2021
- Buffalo MN
Ran into this issue a few weeks ago.
Got a 2019 tcat with atac and whenever I shut it off for a bit it defaults back to firm instead of where I left it at.
Any idea of where I can change this? Also how do I set the rider 1 and 2, it's a 2019 but was flashed this year.
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
A couple things, 2019 iACT do not have multi driver settings, this is only available from 2020 to current.
The issue is that once you are in the iACT mode and make your selection you need to lock that setting by pushing the center program button.... If not... While you are in iACT mode switching through the 3 settings it will revert to the last locked setting.
stgdz
- Mar 27, 2021
- Buffalo MN
Appreciate it, I know that the later models had the driver selection but wasn't sure if I could update that.
Did not know about the lock push for locking atac.
throttle_out
- Dec 21, 2023
- Holmen, WI
- 2019 Yamaha Sidewinder LTX-LE
I have a TD Powertrail Tune on my '19 SW, I had the same issue since tuning it. I can set the iQS to Soft, Med or Firm just fine, but after you shut the sled off, and turn it back on, the setting defaults back to firm. Did you ever find a fix for this? I brough this issue up with TD, and they said their tunes don't affect the iQS at all, but that's when the problem started.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Look up I think you'll find your answer.I have a TD Powertrail Tune on my '19 SW, I had the same issue since tuning it. I can set the iQS to Soft, Med or Firm just fine, but after you shut the sled off, and turn it back on, the setting defaults back to firm. Did you ever find a fix for this? I brough this issue up with TD, and they said their tunes don't affect the iQS at all, but that's when the problem started.
throttle_out
- Dec 21, 2023
- Holmen, WI
Thanks, but I do "lock" the setting by pushing in the center of the button. I can change between soft, med and firm whilst the sled is running, as per normal, and the setting stays to whatever I select, while running. The issue is, after riding the sled and shut it off, when I go to start it again, the iQS defaults back to firm, it doesn't/didn't "remember" the previous setting that it was on prior to shut-off, and I have to cycle through and select soft/med/firm again. Maybe it's the iQS module, but everything else functions with it just fine, it just doesn't remember the last setting after shut-off/on.
stgdz
- Mar 27, 2021
- Buffalo MN
Still having problems with it.
