Powder lites Stage 2 ????????,s
sledheadgeorge
Ontario
Canada
Which one? I have 6
Anyone running a Powder lites stage 2 kit on an Apex?
Please feel free to PM me with the info so no TY vendors are offended and this thread stays civil.
Looking for some feedback regarding:
Reliability
Installation issues
Clutching
Guages
Self installed?
or Vendor who installed it for you, Happy with job?
Happy with kit?
Powder lites kit on your seld vs other kits on your buddys?
I think you guys get the picture. ;)! Appreciate your feed back.
I'm running a Powderlites Turbo on my Apex, I trail ride first and do some lake racing for giggles My sled runs flawless, I run pump fuel with the head shim and never had to put as much as a screwdriver to it. In my opinion all the kits out there are top notch.
I truly believe 90 % of the failures,glitches and breakdowns are install related, If your not capable of doing it yourself I can't emphasize the importance of having a qualified shop doing the install.
I am not going to puff smoke up Powderlites a$$ but his product and support are second to none, but then again I have had dealings with most shops on here and I will say the same about all of them.
Giddy-up :Rockon:
No problem. Powder Lites are TY sponsors so you are free to talk about them unless you have a spesific problem with a kit you bought from them. If that's the case you will have to take the problem directly with Powder Lites, not here in the open forum.
My friend runs a Powderlites stage 3 kit in his Attak, it works perfect and makes too much power for his clutching at this moment, we can't keep it off the rpm limiter at 12 lbs of boost giving it wot from a standstill. He will have to ease into the throttle for a few sec before giving it wot. He runs a 144 x 15 x 1.5 Crossover track so tracktion should not be the problem :-)
Oh Yeah
I am running a 144 track and STM Clutches,The stock Yammie clutches are good but with the higher HP Grabbing the belt becomes an issue,TURK should be able to put you in the right direction there or grab your ankles and go for the big bucks (STM) :Rockon:
I will :-) and I have already asked him a few questions.
thanks for the replys and PMs guys. Any one using one of these kits for trail riding and had any issues with the header pipe cracking?
I trail ride mine weekly (Old Forge trails) no cracking issue's as of yet
Stage II Powderlites ;)!
I think in a front mount the header would be my main concern. We put on some high millage here in Canada and just looking for reliableility.
I remember reading about a cast header does anyone know were the thread is?
cast header is for the nytro only. and Ulmer Racing has them, The newer style headers coming out from powderlites have no cracking issues like the old ones.
seriously, if he can't keep her off the rev limiter, at...... 12psi fro ma start, houston there is a problem... do the clutch bushings are still any good?
You will have great performance and reliability with Powder Lites turbo kits, your safety would be the biggest concern, the power will be very very sneaky
New clutch coming... problem solved.
There is nothing wrong with the old clutch.
