Powder pros Shimming
nytrortx149
Duluth, MN
Has anyone tried slp powder pros? if so did you shimm. I just bought a set and went for a ride and darted really bad. I wanted to go home and put stock ones on again.
With the front of the sled in the air are the ski tips pointing slightly upward?? They should be. Also I believe the powder pros have 2 mounting holes. Move them to the hole closest to the rear of the ski and this should help. What kind of runners are you using?
I am not shimming and using the stock rubbers. But my suspension is not stock. I am running tripple rate springs in front, dual on the center, and I am running 6" shapers for carbides.
i have my stock rubber in it because it seemed to be better than the one that came with it. But yeah they do point down. and i have just woodys singles on 6''. what do i use to shimm it up? thanks
